cooling fan problem???
Old Sep 1, 2005 | 12:52 PM
gibbo frst's Avatar
gibbo frst
Default cooling fan problem???
hi all.. the fans on my 2wd saff come on which seems a lot quicker than they did before do not turn off until about 30 seconds after the ignition is turned off.. the car does not get hot even after ticking over for ages and stays around the R on the NORM... i did have a problem with the wiring and i re wired the live to the fan from the battery with an in line fuse.. im wondering now if maybe this is the problem maybe too much power to the fans..??? any ideas please.. also new pace rad and fan switch.. allong with everything else so im sure its sonething ive messed up.. cheers
Old Sep 3, 2005 | 03:52 PM
rabmc's Avatar
rabmc
Where do the fans come on on the guage ? mines is just a bit higher than O in the guage
Has this maybe changed since fitting pace radiator ? this could be the way its ment to be with this radiator / cooling as in different from what your use to , i changed the thermostat recently in my car and it helped my tempreature
Old Sep 3, 2005 | 04:12 PM
gibbo frst's Avatar
gibbo frst
hi.. yeah they come on below the R less than half way. i have replaced everything now.. engine, all hoses rad ( old one was fine just wanted a shiney one) thermostat, fan switch.. thinking about it has only been playing up since i re wired it.. maybe its drawing too much current..? the car does warm up quickly once driven ..
IainRS1700T
Sep 25, 2015 06:44 AM
simonmcf
Sep 22, 2015 08:40 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Flateric_2002
Sep 15, 2015 08:41 AM
21
Sep 14, 2015 06:38 PM
