mk6 van
Old Sep 1, 2005 | 09:07 AM
wimble's Avatar
wimble
Default mk6 van
how do you lower a mk 6 van please help :wall: :wall: :wall:
Old Sep 1, 2005 | 12:40 PM
GrimmeRS2K's Avatar
GrimmeRS2K
u put the leaf springs under or over the axel, cant remenber which
Old Sep 1, 2005 | 04:18 PM
russel7.wanadoo.co.uk@fs's Avatar
put it over will lower it by about 4 inches,,,, i would do it to my mk 5 but it has about 500 lb of sound system in it and i dont think the u bolts will take the waight
Old Sep 2, 2005 | 12:17 PM
wimble's Avatar
wimble
just looked and the leaf springs r over the axel and its sitting of the 16 about 4 inch
so i think the springs will go under the axel
Old Sep 4, 2005 | 12:01 AM
Al Bags's Avatar
Al Bags
Proper way is to use De-cambered springs .. or get yours done.
If you use the undermount idea, you may need to cobble up the plate-to-axle and weld to casing correctly. Not as easy as it sounds. This locates the axle to the spring correctly.
Things to be careful of are .. Bump stop clearance (suspension travel)
Damper - Range-of-movement.
For the record, I have a Mk4 with decambered springs. Dropped it 4" ... and the twin JL 15" W3's and a few amps dropped it the extra 1"
I had to modify (rework) the bump-stop plate on the chassis rail to give an extra 1" of travel before it contacted. Otherwise, it will go solid suspension most of the time!
Neil Clark
21
Oct 1, 2015 07:02 PM
AJC
Oct 1, 2015 06:47 PM
Flatlinedan
Sep 18, 2015 12:41 PM
S3an
13
Sep 13, 2015 10:01 AM
