2wd Sapphire buying advise
Old Sep 1, 2005 | 08:14 AM
rand's Avatar
rand
Default 2wd Sapphire buying advise
I'm on the look out for a 2wd Sapphire is the anything in particular I should be looking for, rust etc any help would be great.
Andy
Old Sep 1, 2005 | 09:02 AM
lamb chops's Avatar
lamb chops
Hello Andy,
Have a good look under the rear end for rust, the places they go are the rear box sections above where the rear beam mounts to the chassis. It quite hard to see in there so run your hand along the section and see if you can feel any holes. If it is starting to go it’s not the end of the world but the box section is no longer available from Ford so your going to need to get it patched up.
Other than that the rear arches are prone to going but that’s easy to spot. As for the engine listen for piston slap when starting from cold, a fair few do this and it should stop after 30 seconds or so, if not then walk away.
Check for the usual smoke on startup ect and excessive smoke on overrun could be the turbo knackered. Cossies do tend to smoke a little anyway, especially when letting off the throttle at high ish RPM that’s nothing to worry about. If its chipped expect some black smoke when being booted that just unburnt fuel.
Good hunting!!
Old Sep 1, 2005 | 10:46 AM
john_p_b's Avatar
john_p_b
all the things said above really.
check the inner wings etc, it's becoming more and more difficult to buy a sapphire cossie that hasn't been intermate with another vehicle or solid object at some time in it's life. not the end of the world but just look for poorly patched up motors.
lift the boot carpet up and have a good look under there, saw a fair few with rotten floors and spare wheel wells.
good luck in your search!
Old Sep 1, 2005 | 12:53 PM
rand's Avatar
rand
Default Buying advise
Cheers people Just got to find one now!!
FlashRS
13
Aug 31, 2015 06:02 PM
rog
Aug 30, 2015 05:32 PM
markk
18
Aug 17, 2015 05:19 AM
ray barker
Aug 7, 2015 09:00 AM
Old ford
Jul 31, 2015 06:50 AM
