Block and head water leak check...WHO CAN TEST??
Old Aug 31, 2005 | 08:03 PM
Mr C's Avatar
Mr C
Default Block and head water leak check...WHO CAN TEST??
Hi, I have a 2wd sapphire with water in the sump, I removed head and the Hgasket sealed great, Im running ARP stud and nut kit on 205 block, 145,000miler. Who can check my head and block for porousity and leaks under pressure etc? I want to find the route cause of this before selling the parts on as I hate messing buyers about . I have a new engine being built so parts are ready FOR SALE as soon as I have these items checked...HELP NEEDED Ta
Old Aug 31, 2005 | 11:31 PM
NMS Badboy^NUTTER^'s Avatar
NMS Badboy^NUTTER^
Probably cracked the block due to using the studs and nuts if they're the short ones, and not the long mountune type.
Old Sep 3, 2005 | 08:17 AM
Mr C's Avatar
Mr C
Possible then as the head looks mint inside and out, no marks or visible damage so block will be removed Cheers ^NUTTER^
Old Sep 7, 2005 | 11:06 AM
2001ode's Avatar
2001ode
Hi,
May be Modine defective. It is rare but why not ?
Regards
Claude
Old Sep 7, 2005 | 07:27 PM
Mr C's Avatar
Mr C
"2001ode" I have checked everywhere that water and oil cool/warm each other, Turbo, Modine, head, block. Turbo was replaced with a NEW T34 .48, and I also checked the modine using mains pressure water hose and neither had contamination. Head looks fine but want it checked for soft spots, leaks etc to be sure and the only item not checked so far is the block, bores look sound, still no rust after 6months sat with the head off, and the stud threads have no visible cracks at the deck face so maybe on the sump side???
Anyway I decided to have another engine to be sure and will strip the old 205 block at my leisure and check the items for defects before selling the good parts on, just to be 100% sure. Regards Mark C
jessie_rs
62
Aug 6, 2019 09:27 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
kevin36
Sep 8, 2015 12:23 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
hopper350
Sep 4, 2015 12:53 AM
