DIY stage 3 saph - what plugs???
Old Aug 30, 2005 | 10:20 PM
FingerZ!'s Avatar
FingerZ!
Default DIY stage 3 saph - what plugs???
I have a DIY stage 3 saph cos - done by previous owner.....
its currently set to 15psi boost, peaks at 17psi - once i have done a few bits, i plan to get it setup to run about 20-22psi if possible
what spark plugs do i need?
been told several different types by various tuners, seems like I could bung any plug in according to the differences in opinions i got!
Cant remember any of the dam part numbers i was told tho so any help and prices much appreciated
Old Aug 31, 2005 | 11:47 AM
john_p_b's Avatar
john_p_b
motorcraft 12PP8 in mine. recomended by GGR and never had a problem sinse gapping them correctly
Old Aug 31, 2005 | 01:17 PM
Dave Henshall's Avatar
Dave Henshall
for std and stage 1 the Motorcraft AGPR12PP8 plugs are spot on, if going more boost, heard people who have had the tips melt off, the Motorcraft 071C are cheap and dont melt and give good cold start and idle running aswell as no on boost misfires.
Old Aug 31, 2005 | 04:31 PM
Jay,'s Avatar
Jay,
Sponsor
ive had shit loads of probs with plugs ngk 8es ect im now on the ford o71c or just pop into ford ask for s2 rsturbo plugs or stu sells em on his site
cheers jay
Old Aug 31, 2005 | 08:56 PM
davidreader5's Avatar
davidreader5
you tell em jay,
DAVE R, BLOODY NGK'S
Old Aug 31, 2005 | 09:16 PM
Jay,'s Avatar
Jay,
Sponsor
lol dave knows of the shite im onabout hey mate hows it goin
jay
Old Sep 2, 2005 | 04:01 PM
2wd's Avatar
2wd
Does anyone have the full Ford Part number on the 071c plugs ???
Old Sep 2, 2005 | 04:11 PM
Dave Henshall
AGPR701C non surpressed.
finis code:5099754
price roughly:2.30 each
Old Sep 2, 2005 | 04:15 PM
2wd's Avatar
2wd
finis code:5099754
super super ....thanks for the quick answer !!! As I understand they will be ok for a stage III kit on 803's, T-34 and so on ...
Old Sep 2, 2005 | 08:25 PM
richm's Avatar
richm
you will be hard pushed to find 701's now.. they have been superceded by 071C
AGPS071C
finis - 1120834
Ł11.23 a set incl. vat retail
nice and cheap and work fine
Old Sep 3, 2005 | 08:38 AM
Jay,'s Avatar
Jay,
Sponsor
retal whats that then lol
jay
Old Sep 3, 2005 | 09:01 AM
richm's Avatar
richm
jay
exactly - so you want to be paying less
Old Sep 3, 2005 | 01:03 PM
2wd's Avatar
2wd
AGPS071C
finis - 1120834
Ok and thanks..I will check that out...
Old Sep 3, 2005 | 03:45 PM
rabmc's Avatar
rabmc
Put 071`s in mine , had denso plugs in it before , with no problems , these 071`s make my car idle funny up and down slightly where as it used to be fine , may need gaping changed though so should work out okk running 1.5 bar
ford do them for about Ł12 a set and the finis is 1120834
Old Sep 4, 2005 | 10:36 AM
FingerZ!'s Avatar
FingerZ!
thanks for information fellas - i bought the car from pugo off here and he did tell me what plugs to use but i cant remember and havent had them out yet to look. Thought i would ask for a few more opinions and see what teh outcome was. My idle is a bit poo in the morning but other than that it runs good. I think they are 071's - when i heard they were cheap i kinda thought nah it cant be them its bound to be the super expensive plugs that i need - just dont wanna melt them on boost!
Old Sep 4, 2005 | 05:41 PM
2wd's Avatar
2wd
So what gab should it be .... ?
Old Sep 4, 2005 | 05:50 PM
Dave Henshall
my 071c's are gapped at 0.9mm and run 1.9 bar peak with not a single misfire
Old Sep 4, 2005 | 05:55 PM
2wd's Avatar
2wd
Ok and thanks
Old Sep 4, 2005 | 10:09 PM
FingerZ!'s Avatar
FingerZ!
excellent! 0.9 it is
Old Sep 5, 2005 | 12:37 PM
Kam B's Avatar
Kam B
wat about denso plugs? i run them, they need chaning now, runs spot on, where do i get em from?
rang up halfrauds and they have nkg's which are Ł11 which is cheap how much are the denso ones?
my car is stage 1 remapped
Old Sep 12, 2005 | 01:13 PM
2wd's Avatar
2wd
AGPS071C
finis - 1120834
Hmmm...Ford Denmark tells me that the AGPR 701c (5099 754) has been superceded by a plug called AGP 701c...are they they the same...
And also they say that the AGPS 071c (1120 834) has been superceded by 5099 773....?????
Soooo..........
Old Sep 12, 2005 | 01:47 PM
Dave Henshall
phone msd or mike rainbird,
Old Sep 12, 2005 | 01:49 PM
2wd's Avatar
2wd
phone MSD or mike rainbird,
Ok
tankybaby66
Feb 6, 2016 02:24 PM
Rsmat
89
Oct 12, 2015 07:50 AM
A.t.p
Sep 29, 2015 05:04 PM
Russ Payne
Sep 25, 2015 08:29 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
