Puddle of water
Old Aug 30, 2005 | 09:49 AM
steviestarship's Avatar
steviestarship
Default Puddle of water
Hello
This is my first post on here and I need advise on a problem.
I've recently bought a Focus 1.6lx(2002) and at the weekend I discovered a small puddle of water on the floor behind the fromt passenger seat. I checked all over and this seems to be the only place that's wet. I've checked the doors and cant see any faults. Is it possible that the leak's coming from underneath? Only had the car 6 weeks and it only came with 1 months warranty. Any advise on where I would stand with the garage would also be much appreciated.
Many thanks
Old Aug 30, 2005 | 10:25 AM
saphcosworth's Avatar
saphcosworth
There could possibly be a leak in your sunroof or window seals and the water is running down the inside if your panels and out beside the floor in the back. I had a simalar problem with back window leaking and the water would run to the front of the roof and leak out of the map light holder
Old Aug 30, 2005 | 12:29 PM
Moondust_crust's Avatar
Moondust_crust
its gonna sound silly mate but get someone to sit in the car while you pour water over it, least that way u will know where its coming from, hope this helps. cheers mark.
Old Aug 30, 2005 | 01:16 PM
cul's Avatar
cul
could be heater matrix after bursting and flowing under the carpet right down to behind the seat.
this happened me in my rs
Old Aug 30, 2005 | 08:27 PM
studabear's Avatar
studabear
take it back under warrantee
i hate water leaks but owning a mk5 esc cab i should be used to em by now
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
