zetec head bolt settings for use with d comp plate
thanks rich another q if u dont mind sealing plate to block i am using curil T sealing compound suplied by supplier how did you put it on(eg brush or just speaded out?thanks tommy
either way - just enough to get an even coating, there should be minimal gap filling requirement if the faces are flat and smooth, so a consistent thin layer is all you need. Any excess will end up getting squeezed into the oilways, bores, boltholes etc which you need to avoid as far as possible.
ekjim
Aug 17, 2015 08:57 PM
xr4x4rs
Aug 6, 2015 09:03 PM
