2wd rear brake wear
Old Nov 20, 2003 | 10:41 AM
B11GNS's Avatar
B11GNS
Default 2wd rear brake wear
Rear brakes seem to be wearing faster then the fronts (rear wheels more dirty then fronts and replacing rear pads often), anyone any ideas?
Old Nov 20, 2003 | 06:58 PM
Jake_N's Avatar
Jake_N
Is brake disk heating a lot ? Check calibers , brakepistons could be jamming ?
hope that helps
Old Nov 20, 2003 | 07:35 PM
B11GNS's Avatar
B11GNS
I will check this although it is the same on both sides, annoying coincidence maybe.
Old Nov 21, 2003 | 05:56 PM
big_wig_074's Avatar
big_wig_074
i get this on mine,change rears at least twice before changing fronts!strange but true!
Old Nov 21, 2003 | 06:54 PM
B11GNS's Avatar
B11GNS
Anyone else have this problem?
Old Nov 26, 2003 | 11:35 AM
B11GNS's Avatar
B11GNS
Had a thought, have been using halfords rear pads, only because they were available at the time and i needed them quick, could this have something to do with it, maybe they are softer or something?
Old Nov 26, 2003 | 12:32 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
yes m8 put 3 sets of pads in my saf and never put any in the front allways wondered why my self
Old Nov 26, 2003 | 12:35 PM
Ian M's Avatar
Ian M
mine does the same allways has i,ve used all sorts of pads mintex 1144, 1155 etc but makes no difference and nothing is sticking on the calipers either
Old Nov 27, 2003 | 09:37 PM
Uncle Henry's Avatar
Uncle Henry
mines the same too. 2 sets of rears and only one front so far. But they are a thinner pad on the back compared to the fronts
Old Nov 27, 2003 | 10:14 PM
B11GNS's Avatar
B11GNS
This is true but my rear wheels are getting more dirty then the fronts.
Old Nov 30, 2003 | 04:15 PM
stevedohc16v's Avatar
stevedohc16v
Mine are the same, the rear wheels always get dirty with brake dust before the fronts. I think its something to do with the hanbrake mechanism being built into the rear caliper, there is quite a strong spring in the rear caliper for handbrake operation which keeps pressure on the piston and therefore the pads also if the handbrake operating lever mechanism shaft within the caliper is sticking this will keep a bit of pressure on the rear pads, i'm planning to strip and recondition my rear calipers this winter i'll see what I find.
Steve
Old Nov 30, 2003 | 04:57 PM
At stevedohc16v just mentioned, is your handbrake sticking, or rear calipers siezing, common problem on all sierras.
original
Apr 28, 2026 05:20 PM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
