Cossie dash clocks, all one unit???
Old Aug 25, 2005 | 11:24 AM
rog's Avatar
rog
Default Cossie dash clocks, all one unit???
i think i may need to replace the rev counter on my 4x4 saph, is this one complete unit, i.e speedo and rev counter or can you remove them and just replace the rev counter???
Old Aug 25, 2005 | 12:01 PM
antony215's Avatar
antony215
Escort Rs Turbo
Im sure you can just replace the rev counter like you can on the escorts
Old Aug 25, 2005 | 01:48 PM
Alvyn's Avatar
Alvyn
they ARE single items(so can change) in one holder(dash)
Old Aug 25, 2005 | 02:33 PM
EssexBoyRacer's Avatar
EssexBoyRacer
as per alvyn.
Old Aug 25, 2005 | 02:34 PM
EssexBoyRacer
oh but note that not all cossie clocks are the same! and the way they fit are different!
Old Aug 25, 2005 | 09:05 PM
rog's Avatar
rog
ok cheers, just that i noticed a rev counter unit for a 3 door on ebay and wandered if the saph had the same kind of setup. Thanks.
Old Aug 25, 2005 | 09:09 PM
EssexBoyRacer
the 3dr clocks are quite different, the font used for the numbering is totally different to the saphs. Im not sure about the physical connections.
Old Aug 26, 2005 | 06:32 AM
foreigneRS's Avatar
foreigneRS
Testing the future
there are 2 different basic layouts of rev counters, they are different in the way that they attach and connect to the circuit board. i think a 3 door will be different to a sapph.
Old Aug 26, 2005 | 06:49 AM
rsjohn's Avatar
rsjohn
2wd sapphire rev counter connections are different to 4x4 sapphire
john
Old Aug 26, 2005 | 08:18 AM
EssexBoyRacer
The rest is the same though. As I bought a set of cossie clocks off here and they turned out to be 2wd ones I think. I still managed to use the rev counter out of it and just put my speedo and temp gauges into the new clocks housing. All the loom connections were the same.
Old Aug 26, 2005 | 09:12 AM
rog's Avatar
rog
yeah i know they are the same, could have worded my post a bit better!
155lee
Oct 24, 2015 11:11 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
Flatlinedan
Sep 18, 2015 12:41 PM
imnoteasy
Sep 7, 2015 09:26 PM
