Going efi...HELP!
Old Aug 25, 2005 | 12:57 AM
Billy_RS's Avatar
Billy_RS
Default Going efi...HELP!
Can anyone give me a list of parts needed to go efi?
Ive been on the rs bible site, but its too complicated for my little brain
Big to any one who can help.
Billy
Old Aug 25, 2005 | 06:27 PM
cuvner's Avatar
cuvner
efi inlet manifold or modded e-rst one to accept injectors, throttle body to suit management system(cossie magagement-cossie throttle body-i think), fuel rail and injectors with pump and regulator e.t.c. to suit injector set up(depends on how much bhp u intend to run) obviously the ecu and loom, crank sensor wheel and pick up sensor, maf or map sensor depending on what management system again! blah blah blah, all parts depend on wat 'efi' u intend to run!! im trying to sort this side of my car out too
Old Aug 26, 2005 | 06:30 PM
Billy_RS's Avatar
Billy_RS
cheers mate
Old Aug 28, 2005 | 01:58 AM
scort's Avatar
scort
Sorry my sites a little bit difficult to understand mate, I try to put in as much info as I can!
Provided by EFi you mean EEC-IV(as fitted to FRST). For the way I did my S2, which is by far the easiest and best way as far
as I'm concerned:
OFAC Fiesta turbo ECU. (OFAB can be used but takes a little bit more work)
Ecu related MAP sensor. (OFAC ecu will need an OFAC MAP sensor)
Fiesta turbo engine, or mixture of adapter plates and a hole drilled in the block for the CPS
EFi inlet manifold, throttle body and charge carrier
ACT sensor, from the fiesta turbo
Throttle body to charge carrier pipe, still available from Ford at the moment!
EFi flywheel, Fiesta RS, XR2i, XR3i (EFi)
XR3i EFi whole loom
XR3i Throttle cable and pedal
EDIS Module and coil pack etc from XR3i (or Fiesta RS)
That little lot should keep you going no probs!
Cunver, I see your from Dorset. Not too far from me, anywhere interesting?
Steve
Old Aug 28, 2005 | 07:21 AM
cuvner's Avatar
cuvner
im based in poole so i lil out of your way, but usually out motoxing in somerset or that way somewhere!! Is there a airfield which gets used as a trackday in somerset somewhere??
Also i was near shepton mallet back in july and a gsxer came past on his back wheel, i was in a red erst!! was this you?? Just a guess from the pic in your siggy
Old Aug 28, 2005 | 11:29 AM
scort's Avatar
scort
Who knows!! lol!!
Yeah, there is an airfield near me, in Ilton called Merryfield. It's literally five miles away. Not heard much about it getting used for trackdays though?
Steve
