Bleed valve good or bad??
Old Aug 24, 2005 | 11:05 AM
antony215's Avatar
antony215
Escort Rs Turbo
Default Bleed valve good or bad??
Just got a bleed valve but after reading up on them not sure weather to put it on or not as some say there good and others say there shit. Ive been told to wined the actuator in a bit as this duz the same job without creating a leak in the boost like bleed valves do. whats the cheap and easy way to increase the boost?? car is more or less standered (s/s and air filter) i know i cant go over 10psi as it's not chipped any idea's people
Old Aug 24, 2005 | 12:48 PM
adamS2RST's Avatar
adamS2RST
Adjust the actuator arm, as mentiond wind it in and it will increase the boost. Lob the bleed valve in the bin
But, as you say you need to chip it to raise the boost limit otherwise it's going to overboost and shut you down when you hit over standard psi
Old Aug 24, 2005 | 12:56 PM
GrimmeRS2K's Avatar
GrimmeRS2K
Bleed valve are good for easy adjustment of boost,
but not for people who keeps turning them up
I ran an amal valve, then the tuner i used just installed a bleed vlave and its fine
The amal valve just started playing up, after a bar of boost, and made a clicking sound at 2k revs which was annoying
Old Aug 24, 2005 | 03:12 PM
AKRS1's Avatar
AKRS1
Can somebody tell me what exactly does the amal valve do and also could i still run 15psi without a bleedvalve
Old Aug 24, 2005 | 04:13 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
as grimmer said
bleed valves are good but tampering with them can be bad
i have a incar bleedvalve taped to my handbrake for easy adjustment tho
and thats connected to a under bonnet bleeedvalve which i can set a upper limit with, atm upper is 20 psi but i dont use it at that cos the clutch dont like it
Old Aug 24, 2005 | 04:34 PM
GrimmeRS2K's Avatar
GrimmeRS2K
the amal valve is basically a bleed valve but elecrtronically control via the ecu
The ecu supplies the amal valve with power to give boost at your set actuator preload
Old Aug 24, 2005 | 05:01 PM
SamERST's Avatar
SamERST
I always thought that whenever adjusting the boost your supposed to get it setup after ??? is this ture or not as ive got a bleedvalve and have always been to scared to touch it lol
Old Aug 24, 2005 | 05:13 PM
addiction's Avatar
addiction
bleed valves are fine as long as they are set up by a tuner and then NOT played with!! the temptation to adjust for more boost can go to far resulting in an engine failure,and you dont want that
Old Aug 24, 2005 | 05:15 PM
GrimmeRS2K's Avatar
GrimmeRS2K
after any boost increase, a setup is needed because of the more air entering the engine and u need the fuel to match
Old Aug 24, 2005 | 07:46 PM
SamERST's Avatar
SamERST
So a 2 stage boost is a better idea
Old Aug 25, 2005 | 07:24 AM
antony215's Avatar
antony215
Escort Rs Turbo
I always thought that anything up to the standered ecu limit (around 9-10 psi) you could do without having to get it set up
markk
Dec 2, 2021 06:59 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
jay030787
Aug 17, 2015 06:16 PM
Mark RS
14
Aug 11, 2015 11:45 AM
mattman1234
24
Aug 1, 2015 11:46 AM
