servo help needed!
Old Aug 22, 2005 | 08:50 PM
Robliddle's Avatar
Robliddle
Default servo help needed!
Trying to bleed my brakes off on my S2 after fitting rear discs but can not seem to get air out of system. but when i washed off some brake fluid i spilt on the master cylinder and servo with water i noticed the water was bubbling around the flandge of the master cylinder where it bolts onto the servo, when the brake peddle was pressed. could this be the reason for air still getting into the system? can anyone help??
Old Aug 22, 2005 | 09:03 PM
Turbo Bird D8BBY's Avatar
Turbo Bird D8BBY
When you are bleeding the brakes are you doing the rears first and then the fronts.... its easier to get the air out of the system that way. My other half swopped my master cylinder and it was a pain in the RS. Must of bled the brakes a half a dozen times.
James Raby's Avatar
James Raby
Not sure about servo, but you need to unbolt the rear calipers so that the bleed nipple is the highest thing on the caliper, in place they aren't
Just loosen the top one and take bottom one out, swivvel it up and bleed away
Rear right, rear left, front right, front left - order to be done in
Old Aug 22, 2005 | 09:36 PM
Robliddle's Avatar
Robliddle
Cheers ill give that a try!
Old Aug 22, 2005 | 10:28 PM
Wazzzer's Avatar
Wazzzer
I take it you'll have to do the same with front 2WD Cos calipers? (as the other nipple is pointing down...)
Old Aug 23, 2005 | 09:38 AM
James Raby's Avatar
James Raby
Wes, presume so, or have you got them upside down
Old Aug 23, 2005 | 09:53 PM
Wazzzer's Avatar
Wazzzer
thought they had 2 nipples cos of the 4 pots, I maybe being a complete twat though
Old Aug 24, 2005 | 07:00 AM
Sketch's Avatar
Sketch
Your being a twat Wes
They have 2 nipples, both facing the same direction (just one on either side of the caliper)!!
Old Aug 24, 2005 | 08:38 AM
scort's Avatar
scort
Unless someone has bolted the wrong sides of the calipers together!
Steve
Old Aug 24, 2005 | 10:03 AM
adamS2RST's Avatar
adamS2RST
I've had similar problems with mine.....see if any of these threads help you out:
https://passionford.com/forum/viewto...204&highlight=
https://passionford.com/forum/viewto...758&highlight=
https://passionford.com/forum/viewto...ghlight=brakes
Old Aug 24, 2005 | 05:28 PM
Wazzzer's Avatar
Wazzzer
ok thanks, thought I was
Old Aug 24, 2005 | 10:00 PM
Quickie's Avatar
Quickie
You said it Wes lol
Old Aug 27, 2005 | 01:30 PM
adamS2RST's Avatar
adamS2RST
You still having problems with this?
original
Apr 28, 2026 05:20 PM
moesin2005
Jan 23, 2022 06:28 PM
c20tbo
Aug 17, 2015 10:19 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
col93saphcos
Aug 7, 2015 03:21 PM
