350 brake
Old Aug 20, 2005 | 05:13 PM
JohnnyR6's Avatar
JohnnyR6
Default 350 brake
My m8 is rebuilding his escort cossies engine. its getting built to be strong and reliable.
once finished what will be needed to get a good 350 bhp from it for reasonable money?
i.e. turbo, ecu etc.
Cheers Johnny
p.s. we prob know what to use but just want it reassured.
Old Aug 21, 2005 | 01:30 AM
Red16's Avatar
Red16
t34 and a large dollop of boost will do it i think, theres a thread in the main forum about whats needed for 375bhp, could be worth a read for you and your mate
Old Aug 21, 2005 | 05:03 PM
Toe Knee's Avatar
Toe Knee
Bit more complicated than that
Is it a big or small turbo escos?! if big then u got the t34 already, althou might be worth considering getting a hybrid one and need at least a -31 actuator and a 3bar map sensor. Next your gonna need dark greens or light blues for that sorta power. Ideally you'll need at least a group a head gasket as standard ones dont like big power. THen its a case of getting a chip 2 suit and set up for that power. But good idea to consider things like a breather kit due to increase crankcase pressures, and things like a 500 type cooler to keep the charge temps down.
Old Aug 27, 2005 | 08:10 AM
wongthecorrupter's Avatar
wongthecorrupter
t34 3 bar greens 25 psi of boost max on greens.
Old Aug 27, 2005 | 02:31 PM
JohnnyR6's Avatar
JohnnyR6
cheers m8, it is a big turbo, most of the stuff we have already inc. greens, -31, breather kit. rs 500 cooler on order and will get a group a gasket.
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
dojj
Sep 29, 2015 10:32 PM
Sp3no
Sep 27, 2015 07:23 PM
