BREAKING FLINT GREY 2WD COSWORTH 7/09 . PRICES **PAYPAL**
The time has come to break my Flint grey cosworth (the one in my sig)
The spec:
Engine has been stripped for inspection, and I am willing to sell in parts.
long studded 200 block freshly bored to +1 - £600
7.2:1 pistons +1 with cutouts - SOLD
standard pistons
balanced crank and flywheel
cometic 3 layer gasket set
ported head - SOLD
standard 2wd head
rs500/3DR?????head
T38 turbo - SOLD
T70 turbo
all manifolds, nuts, bolts and ancillaries etc.
Grey injectores - £130
4 - paddle clutch
aluminium expansion tank
oil separator
cam cover with port
205 block on standard bore
gear box
level 8 ecu with baby board and chip for greys - £200
4x4 tps
BD10 exhaust, BD14 inlet with new followers - SOLD
amal valve with pipes - £20
huge air filter - £45
-34 actuator - £45
spec-R chrome turbo damper - £40
2wd exhaust manifold - £45
2wd diff no problems - £150 provisionally SOLD
abs pump - £60
3 bar map sensor - £55
white dials
flint grey shell including loom etc. including V5 HPI clear.
grooved front discs
front and rear calipers.
1 year old steering rack - £30
Leather seats - £300
17" multi spoke wheels and tyres - £250
good radiator - £50
std 2wd rear calipers - £30 pair
black dash complete - £70
black carpet - £35
blue samco air filter hose for T34 - £20 provisionally SOLD
15" shark tooth 2wd cossie alloy with tyre. - £40 provisionally SOLD
abs pump - £25
2wd pas pump - £25
2wd alternator - £25
Ford motorsport HT leads - £30
Prop Shaft - £40
Rear Beam - £30
Rear Arms - £30 pair or £20 each
Front Hubs - £50 pair or £30 each
Rear Hubs - £50 pair or £30 each
Front Cross member - £20
Headlights - £10 pair
Clear side repeaters - £5 pair SOLD
Clear front indicators - £10 pair
Tinted rear lenses and number plate surround - £60
Fog light surrounds - £20 pair provisionally SOLD
2wd abs ecu - £20
Front anti roll bar - £25
rear anti roll bar - £15
4x4 Bonnet - £120 - SOLD
Rear Bumper - £30
Rear spoiler - £25
Side Skirts no jacking point covers - £40
Doors - £135 for the lot, or £40 each
If there is anything else you want do not hesitate to pm me.
The spec:
standard pistons
ported head - SOLD
standard 2wd head
rs500/3DR?????head
T38 turbo - SOLD
T70 turbo
4 - paddle clutch
oil separator
cam cover with port
gear box
4x4 tps
-34 actuator - £45
abs pump - £60
white dials
grooved front discs
good radiator - £50
black carpet - £35
abs pump - £25
2wd pas pump - £25
Prop Shaft - £40
Rear Beam - £30
2wd abs ecu - £20
Rear Bumper - £30
Rear spoiler - £25
cossiemen you're going to laugh at this too then !!!
Didn't realise this was a 2wd advert, for some reason I thought it was a 4x4
450bhpcossie - Don't need the arms, sorry for messing you about
I'll get my coat.
I'll get my coat.
Hi, PM`d you again re: collection of parts as discussed; PAS rack and pump, 205 block and Bailey turbo damper
Please leave a contact number and I will get these items out of the way mate. Regards Mark C.
