oil return on zt
Old Aug 17, 2005 | 06:02 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default oil return on zt
i have had a look at a few sites and the show you 2 differant ways for oil return 1 in the sump above oil level-how do you mesure?or at the bottom of the block there is a 10mm bolt that you open up and fit treaded pipe into block,will they both do the same job or is 1 better than the other ????
Old Aug 17, 2005 | 06:44 PM
tonyturbo's Avatar
tonyturbo
easier to put it in sump. less hassle. remember where the starter goes tho. bout 1 inch down from top is ideal.
Old Aug 18, 2005 | 07:12 PM
richm's Avatar
richm
oil return from turbo...
breather oil return on the back of the sump...
There will always be strong discussions for, and against, returning below oil level, but these positions worked for us
Old Aug 18, 2005 | 08:29 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
thanks rich if its good for you then its def good good for me top advice from both cheers,tommy
Old Aug 19, 2005 | 05:14 PM
tonyturbo's Avatar
tonyturbo
below oil level or above it doesnt really matter. mine was above an it was fine. .
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
