Will an chipped RST ECU fit on a RS1800 Engine
As above, i cant find any chipped RS1800 ecus so would a chipped rst ecu fit in. Also if you know of anyone who has one availible please let me know
cheeRS
cheeRS
yes could be the answer your other post said you are thinking of zt conversion on your 1800 then you could run frst management but its not just a case of plugging
it straight in you will need all the other sensors and a engine bay loom(note there are 3 differant types of frst managment,i think 1 to go for is ofab or ofac i think both are compatible)hope this helps,tommy
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
