Grab urself a bargain...part deux
Had a clearout the other day so thort i'd give you lot first shout before this lot goes on fleabay
EFI plenum (not frst) £15
S1 Plenum with knock sensor? £15
Standard xr3i back box nearly new £10
Couple of Samcos erst £15
Pedal set new £10
Standard ford radio £10
S1/XR3i Maxtorq pads new £20
Coil packs £20
rst mfi head £50
S1 cold start relay £5
EFI crossover pipe £5
RS 2000 mk5 fan £5
passenger side mk4 h/light £5
both sides mk3 £5 each
rst starter motor £20
rst alternator £20
mk5 RS 2000 f/bumper needs painting £10
Pedal set new £10
Coil packs £20
rst mfi head £50
RS 2000 mk5 fan £5
rst alternator £20
