compression question
Old Aug 15, 2005 | 02:08 PM
cul's Avatar
cul
Default compression question
I did a compression test on my zvh during the week and found that on each cylinder i got a reading of 10 after the third rotation of the engine .
i then did a wet test and the reading stayed the same.
Does this mean that i can rule out the piston rings beaing worn????
Old Aug 16, 2005 | 03:15 PM
cul's Avatar
cul
any ideas?
Old Aug 16, 2005 | 03:42 PM
Badman38's Avatar
Badman38
your piston rings are ok what problem are you having?
Old Aug 16, 2005 | 06:47 PM
cul's Avatar
cul
my car is smoking and burning loads of oil.
When i start the car in the morning there is a patch of oil spatters on the ground and if you put your hand over the exhaust for a few secs on idle there will be oil on your hand.
When acclelerating any bit there will be blue smoke, (not on back off but when you actually accelerate).
there is no unusuall amount of oil in the boost pipes or play in the shaft of the turbo.
and the valve seals are about 6 months old.
but i did find oil on the plug in cylinder 3 and all the rest are perfect.
any ideas?
Old Aug 17, 2005 | 06:53 AM
Badman38's Avatar
Badman38
any ideas?
when my rings were gone i use to get a misfire at idle but once i was over 2000rpm car seamed ok.The turbo was bringing compression up,but boost was blowing past the rings into the crank case Pressurizing the crank case so in turn blowing all my oil through the breather . compression for each of my cylinders 1-100psi 2-130 3-130 4-130 plus number one plug was black and the rest were ok. so it does look like you have the Symptoms of worn rings, but i cant understand how your compression for all four cylinders are the same .
Old Aug 18, 2005 | 11:17 AM
cul's Avatar
cul
is it possible that it could be a valve seal over the third cylinder letting oil onto the plug and blowing it out the exhaust.?
Old Aug 19, 2005 | 11:57 PM
gavintwopies's Avatar
gavintwopies
It does sound possible. what make were the valve seam seals you used? ,were they the uprated type that the valve spring holds in place? or the cheap crappy type that just push on as they dont last 5 mins
Old Aug 20, 2005 | 09:09 AM
cuvner's Avatar
cuvner
I recomend buying the haynes manual for the cvh engine, it gives good diagnosis to all engine noises oil loss etc etc It give loads of examples for pinpointing problems, it says comp test for wet and dry should be similar, worn bore/rings would bring compression up, leaking stem seals it would seem but your head might need overhaul as it could be worn valve guides aswell! goodluck
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
