uprated fuel pump
need to fit a new fuel pump to the car, should i go standard or is there a good uprated alternative (have heared about fitting cossie 2wd) any one got any idea, running about 198bhp at the moment, and thinking of a zvh conversion soon
A cossie pump only has different terminals, nothing more
If you having problems with fueling, re-do the connections of witing on the pump
If not, adding another fuel pump won't give you more fueling, just a better connection and feed
I cut off ends and re-do every year on my pump, better safe than sorry and always a good connection then
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
standard pumps for an rsturbs are kewl for 400bhp!
if its noisy,then the impeller is slipping on its spline,and not giving the pressure needed,soon the pump wont pump,trust me i know!
Originally Posted by RSTEVE
will see whats avalible 2nd hand and the price.
New ones about Ł70 at a Bosch dealer, maybe cheaper if you haggle
just spent ŁŁŁŁ on a rebuild + ŁŁŁ on new brakes + ŁŁ on tax + ŁŁ on insurance
+ wife and 2 kids =even less ŁŁŁŁ
i know it makes sense to buy new but i need to watch the ŁŁŁ if i can get one used on the cheap i will do untill i can afford a new one next month.
good second hand below 20thou miles no external damage,there usually ok for at least 80thou,mine was genuine to 110thou miles.
I use a standard S2 pump and haven't changed it in the 9 years I've owned the car.
The S2 and Cossie pump are not the same. I thought this and was corrected, apparently they have a higher flow rate
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
still not sure which to go for will see whats avalible 2nd hand and the price.
