Oil leak from Pressure Gauge
Just connected up oil pressure gauge, all works fine apart from where the hose from the gauge joins the three way adapter, it seems to keep on leaking oil. The connection has been tightened up as much as it can, with the little washer in place, but still it leaks. Has anyone had this sort of problem who could advise me as to how to over come it. Any advise would be highly appreciated
CheeRS
CheeRS
i had this problem with a gauge i bought, i sent it back and asked for a new one which i got, new one leaked too so fucked the idea of, more hassle
that what its worth, get an electric one instead of mechanical
Originally Posted by Micky
Try some PTFE tape on the treads before you screw it into the adapter.Regards Micky
krypton
Sep 23, 2015 07:29 PM
