PSI to Compression Ratio
Having looked at a few articles I relised its not as easy as I first though, but could anyone hazard a ruff guess at what it might be?
Its a 3dr with a 2wd head a 200 block, not a lot of help I know.
Tar Rich
Tar Rich
the engine is not the standard engine if it has the 200 block.
so have a look thru your reciepts for the engine rebuild (if you have them)
and see if you can sus out what pistons were used mate
Already tried that, no reciept for the bottom end I'm affraid.
Does the PSI reading have any bearing on the compression ratio, ie does it sound low comp?
Tar Rich
Tar Rich
gotta turn the boost up and see
i take it you are going stage3 with 803's? good conversion on standard comp
T4, Greys, recon head with BD10's, RS500 Innercooler, WRC Head gasket and Grp A Everything else.
Before I bought my 3dr it was meant to be running 450BHP, but the guy just put the engine pretty much back to standard but left the block in it. Then sold it to a dealer which is where I bought it. At the time I was like "ye cause it was running 450" but I bought it anyway
Now I've bought loads of goodies for it to take it up to at least the 400 mark but still not sure about the block. it is a 200 block so I think is probably been moddifed.
Think I'll just get it setup and see how much boost it takes before it starts to det.
Rich
Rich
