electric fuel problem with mk4 escort efi turbo
Old Aug 14, 2005 | 10:24 AM
efiturbo's Avatar
efiturbo
Default electric fuel problem with mk4 escort efi turbo
I have a Mk4 Escort cabriolet which has mk4 escort wiring loom, with Fiesta turbo add ons,its got a 195 chip with beige injectors,t3 turbo and a high boost cam,i am having problems with it over fuelling.Its had new fuel pump,and regulator,injectors have been changed to standard but made no difference so i changed them back.Does anybody know of any known electrical problems with these after having this conversion??
Old Aug 14, 2005 | 11:37 AM
tonyturbo's Avatar
tonyturbo
is the map sensor wiring correct? mine over fuelled and thats what was causing it. what map sensor are you using?
EoinXR3
Sep 7, 2015 05:44 AM
A.t.p
Aug 15, 2015 11:37 AM
dlwarrior
Aug 5, 2015 10:19 AM
adriansaleem
Aug 1, 2015 09:28 PM
3i Jim
Was It You?
Aug 1, 2015 06:33 PM
