ignition coil
Old Aug 13, 2005 | 10:19 PM
cosbag's Avatar
cosbag
Default ignition coil
Hi
Can anyone help me!! I want to no if my ignition coil should spark once when i turn the ignition on or whether it should continuiously spark whilst cranking the engine over?
Would be very grateful if anyone could help!
cheers
Old Aug 14, 2005 | 10:35 AM
Dave Henshall's Avatar
Dave Henshall
if its a esocs or 4x4 saph, i know these both fire the coil once when the ignition is turned on.
it should fire 4 times per revolution of the engine when yuo are turning it over.
Old Aug 14, 2005 | 11:15 AM
DazC's Avatar
DazC
It HAS to spark (as Dave said above) when cranking other wise it WILL NOT fire up....
Old Aug 14, 2005 | 08:35 PM
cosbag's Avatar
cosbag
cheers i found out the crank sensor was broke thanks again
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
beller
Sep 21, 2015 04:13 AM
