Gap on NGK BCR8ES
Aug 13, 2005 | 01:21 PM
Gap on NGK BCR8ES
What have you found works best at 14,5+ psi? The standard 0.8mm or something else?
Aug 13, 2005 | 02:49 PM
mine are closed in a bit, but i run more boost, rs turbos do tend to blow the spark out sometimes when running more boost
Aug 15, 2005 | 09:26 AM
0.8 is fine, but when u say 14.5+ psi, what boost do you mean then 40psi???
Nov 1, 2015 06:53 PM
Chas
Oct 5, 2015 07:13 PM
pabloXR
Sep 21, 2015 12:42 PM
Bailes1992
Sep 19, 2015 02:17 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
