calling all wireless network gurus
Old Aug 13, 2005 | 09:15 AM
Gra's Avatar
Gra
Default calling all wireless network gurus
I am trying to connect my sony vaio to the internet via wireless, i have a wireless card in my router and my sony has built in wireless, and i can connect and get a good signal but cant connect, my router is fine because it was configured at work (work provide Broadband) and my old toshiba used to connect fine but i dont know much about conecting wirelessly and not sure how i set up my sony vaio to connect, any onegot any ips or advice please?
Old Aug 13, 2005 | 09:17 AM
rsnissan's Avatar
rsnissan
is the wireless router giving out DHCP?
Old Aug 13, 2005 | 09:45 AM
Gra's Avatar
Gra
yep cheers
Old Aug 13, 2005 | 10:14 AM
Stu.H's Avatar
Stu.H
ive got a vaio with inbuilt wireless
u saying ur getting good signal, but cant connect? i presume web browsing?
can you ping web addresses?
Old Aug 13, 2005 | 10:17 AM
rsnissan's Avatar
rsnissan
can you get the web using the router with a patch lead? (to make sure your proxy settings etc are spot on)
Old Aug 13, 2005 | 10:23 AM
Stu.H's Avatar
Stu.H
sounds like poss the router isnt getting an IP from your ISP, have u tried rebooting everything as I have to with my configuration for the router to get an IP.
have u logged onto router to check "status" and see if it has a proper IP, and not one starting with 169.
Old Aug 13, 2005 | 10:44 AM
Gra's Avatar
Gra
hi
thanks for the replies, if i connect with a patch lead then everythings fine, if i use wireless i get a signal but cant connect or ping, but if i use my old toshiba then wireless works fine no probs so i figured maybe the vaio needed setting up
Old Aug 13, 2005 | 10:56 AM
Stu.H's Avatar
Stu.H
define "cant connect" ??
Old Aug 13, 2005 | 11:11 AM
Gra's Avatar
Gra
sorry bad choice o wording, i mean i cant open any web pages
Old Aug 13, 2005 | 11:37 AM
Gra's Avatar
Gra
may have found the reason, it says its a security enabled network, so would i need to enter a network key? as i have ticked "provide one automatically" could this be why? and if so where do i get the key as i cant find it on the config pages for the router
Old Aug 13, 2005 | 12:58 PM
T38Mat's Avatar
T38Mat
I always specify WEP. Create a code in hexidecimal and put it in the router (usually in wireless/encryption menu) and save the setting. Then on the laptop try and connect to the network and it should offer a key window, drop the code in there (usually twice ) and that should be it.
Hope this helps.
Old Aug 13, 2005 | 01:45 PM
Stu.H's Avatar
Stu.H
yes that would be why gra
wep is set up on the AP, and getting one automatically wont be any good.
unless you know the password/key, reset the router completely and set up again.
stevecfrst1
Sep 30, 2015 05:18 AM
rsguy
44
Sep 29, 2015 03:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RSmark84
Sep 13, 2015 01:29 PM
