General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
can make out the return off this pic. The oil feed comes from the back of the block (outlet with the oil pressure switch) via a braided hose to where the yellow bung is on this picture.
you can make out the green gasket, thats the return, solid pipe going to flexible pipe with just a heat protective tape round it going to the block with just spring clips holding it either end.
