Throttle bodies
Old Aug 12, 2005 | 03:52 PM
Keith B's Avatar
Keith B
The length of the inlet tract will affect the torque curve as will the radii of the bellmouth for the inlet trumpet. Longer inlets are better for low down torque and shorter ones are better for top end power.
Old Aug 12, 2005 | 04:13 PM
ian sibbert's Avatar
ian sibbert
Have a look at this site mate in advice and FAQ it expains it really well
Regards
http://www.jenvey.co.uk/
Old Aug 12, 2005 | 04:14 PM
Jamz's Avatar
Jamz
To quote 'Forced Induction Performance Tuning' by A. Graham Bell
long runners will push up bottom-end power, but once past the peak the engine will fall flat on its face. Short runners do the opposite - they kill the bottom end and help the engine maintain power way past the peak
Old Aug 12, 2005 | 04:45 PM
Keith B's Avatar
Keith B
I mentioned this in another post recently but I remember the 1990's Renault F1 engine having variable length inlet trumpets that would telescope up and down with the engine rpm - it was awesome to watch and obviously the variability gives the best of both worlds.
The radii on the inlet trumpets affects the flow rate also. There are alot of variables you can tune.
Old Aug 12, 2005 | 05:15 PM
NUTS RuS's Avatar
NUTS RuS
I have direct to head TB's as generally the car is running up in the top end of the rev range.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
