boost and afr gauge for sale
Old Aug 12, 2005 | 09:11 AM
Tim's Avatar
Tim
Default boost and afr gauge for sale
Nomad 30 psi boost inc post £20
Afr phantom autometer inc sensor which i have no idea how you wire up came off may wrote off cossie never checked before i cut the wire lol doh.
£40 inc post
Old Aug 12, 2005 | 12:27 PM
moonstonematt's Avatar
moonstonematt
Tim,
ill have the afr meter mate! pm me an address and ill get a cheque or do you except pay pal???
Old Aug 12, 2005 | 07:49 PM
Tim's Avatar
Tim
pm ed ya.
Old Aug 12, 2005 | 08:59 PM
xrsi's Avatar
xrsi
could help a little with the wires! just fitted one onto my fiesta!
right on the lambda sensor the 2 white wires are for the sensors heater then the other 2 will be a feed and an earth i think, i only used a 3 wire lambda sensor on mine!
on the gauge, the red isd switched live, the black is earth and there should be i think either a purple or blue wire on the gauge, this is for the feed from the sensor!
Old Aug 16, 2005 | 01:04 PM
db's Avatar
db
Hello XRSi,
I have a few questions concerning the above:
(I am fitting a lamda sensor in my S1)
did you fit the lambda sensor in the exhaust yourself?
If so how did you do this?
Were do the 2 white (heater) wires go?
And are they connected directly to the ignition, or is a relais required because of the electrical current?
Thanks for answering the questions!
Cheers, Dimitri.
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
