FRST EFI
Old Aug 11, 2005 | 09:55 PM
adamS2RST's Avatar
adamS2RST
Default FRST EFI
Hi,
Going to get a FRST setup and have heard it's best to get an OFAB setup to run more boost? But you can mod OFAC to run as OFAB or something? Is that right?
Also, if I dont have edis module, map sensor etc off th one engine does it matter if I use these parts from another engine? Not clued up on the efi side of things
Ta very much
Old Aug 11, 2005 | 10:00 PM
CraigN's Avatar
CraigN
its not quite that simple
and unless your running a badboy engine and turbo then ofac will be fine
Old Aug 11, 2005 | 10:05 PM
adamS2RST's Avatar
adamS2RST
Oh, I thought it was changing a few wires / pins....oh well #
I thought OFAC you can run a max of 1bar boost?
Old Aug 11, 2005 | 10:10 PM
Oranoco's Avatar
Oranoco
1.1 bar but I seem to remember Stu saying this was an easily sortable software issue.
Old Aug 11, 2005 | 10:13 PM
adamS2RST's Avatar
adamS2RST
OK, so is there any other reason to not use ofac do you know?
Old Aug 11, 2005 | 10:27 PM
Rab's Avatar
Rab
Fucking superstar........
I have a spare OFAB and Map sensor. OFAB uses the Weber type map sensor hence you can run more boost with it.
Old Aug 11, 2005 | 10:30 PM
adamS2RST's Avatar
adamS2RST
Cool, still waiting to find out which it is anyway. Cheers for the answers peeps, at least I know it can be converted some way
mk1turboestate
Dec 2, 2015 08:31 PM
davidfordrs
Sep 21, 2015 04:23 AM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
