t3 turbo wastegate
do the penny washers inside the esrt wastegate housing wear??
reason i ask is that ive been loosing boost on my car and i took the housing off to see if this was the problem and i noticed that the washer will not sit flat against the hole as it appears to have worn.
when it is fully shut it is not level with the exhaust housing.
anyone had this trouble or knows a bit more about turbos??
thanks
Dave
thanks
Dave
thats the problem.
when you look at the elbow across the flange that would bolt to the exhaust housing the washer is at an angle so that it would only contact fully along one side.
as if its worn or bent.
thanks
dave
thanks
dave
thatnks guys,
treid 'adjusting it ' this afternoon, now it has a crack in the arm
Tommy give us a pm with what you want for it pal
i assume ther all the same regardless of what stage t3 you have
thanks
dave
thanks
dave
JK12
33
Apr 26, 2021 12:09 PM
