Cooling on GRS
I've just got my GRS for my ERST and was wondering whats the best way of cooling for the rad.
I've got 1 10" Kenlowe already but is it worth getting another one?
I've seen people running one fan, 2 fans, one/both on the outside of the cooler, one/both in between the rad and cooler, so whats the best?
Any advice much appreciated
I had the first type of GRS, which is 10mm thinner than the ones out now. I had one Kenlowe in the middle, and then moved it to the front.
Cooling was better with on the front, but ACT's were worse. The cooling was never great, and couldn't be kept undercontrol in the summer without having the heaters on full blast. That was using an 82degree thermostat too.
Now, I have 2 fans controlled independantly fitted on the rad, an alloy rad, an 82degree thermostat and will be having the back of the bonnet open slightly. Fingers crossed that I won't need to use the heaters this summer.
HTH
HTH
Cheers Tone, I will probably end up getting another one and putting them in between the rad and cooler...
I'll put just the one in for now and see how the temps go
I have a pair of Kenlowes between the rad and intercooler and a 82 stat, works okay but learnt to use 130 anti-freeze to be safe. Lifting bonnet made no differences but looks
i got 2 fans but only fitted 1 as i couldnt get the other to fit on the std rad
i presume i need an ali rad to fit 2 behind the cooler????
but ive just fitted a co2 cooler for the grs so mabe it might cool the rad down aswell
i presume i need an ali rad to fit 2 behind the cooler????but ive just fitted a co2 cooler for the grs so mabe it might cool the rad down aswell
Since my 'incident' not so long back I'm back to a std rad still running 2 x 10in kenlowe fans between rad and intercooler, still having no problems, but with std rad runs a bit warmer than the alloy rad I used to have
Originally Posted by BODGE
rob they do fit you need to cut the outer housing of the fans to fir over the end tanks
mark
mark
