How do I plumb in an AMAL valve?
Old Aug 11, 2005 | 12:09 PM
EvilFranky's Avatar
EvilFranky
Default How do I plumb in an AMAL valve?
Havn't run one since the T3 conversion years ago, but with me wanting to get rid of the car i want everything as spot on as possible.
The car runs a 2 way bleed valve at the moment, one pipe from the compressor housing and the other going to the actuator.
Am i going to need a 3 way bleed valve to run this? Or is there another way of plumbing it in?
Old Aug 13, 2005 | 08:25 AM
Stu @ M Developments's Avatar
PassionFords Creator
Each stub is labelled if you look carefully before you fit it:
C = compressor.
W = Wastegate.
R = return to metering head.
Old Aug 13, 2005 | 02:02 PM
EvilFranky's Avatar
EvilFranky
Cheers Stu,
How do I hook it up with a bleed valve installed though?
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
