Numbers stamped on CVH block
Hello All, I'm in the process of rebuilding a 1600 CVH Turbo Efi motor..I have a few spare blocks to choose from and on the deck of each there are numbers stamped in the corners.
Two have "32" and one has "22". Do these relate to the bore size/tolerance of the original engines, or is it something else?
Cheers!
Cheers!
