pic request - 4x4 saph with 40mm lowering springs on please!
Pictures, video & Photoshop ForumIf you want to show off your photoshop skills, share pics and videos of your car or other cars you've found, here's the place to go.
I have been told this evening that a 20mm drop on saph 4x4 springs is less than a 20mm drop on 2wd springs - is this right?? do the 2wd's sit lower as standard, therefor when put on a 4wd they drop about 40mm??
I have been told somthing like that in the past, ecos and 4x4 saff springs are the same but 2wd are different, I would go for a new set of 4x4 springs if I were you mate
