Turbo noise ??
Old Aug 7, 2005 | 05:44 PM
rs-nut-john's Avatar
rs-nut-john
Default Turbo noise ??
just got back from the ford fair and i treated my S2 2 a new -31 act as mine was poor as piss...
i fitted it there and then and drove it home 180miles back to Doncaster. I wound the pre-load in just enough so i could pull it over the wastegate. It boosted straight away and very smoothly 2, however it went 2 18psi then held 16ish, but my turbo sounds like a jet plane taking off, its very loud so on the off chance i didnt let it go past 10psi incase of over-boost...
its chipped with all the usual sensible mods, and when i arrived home the tailpipe was a light black/grey....
So does it sound like the turbos gonna go pop or is it normal for it 2 b loud ????
Old Aug 7, 2005 | 05:50 PM
Stoo's Avatar
Stoo
Well what boost was it running before you fitted the new actuator?
Ifi t spiked to 18 and held 16 before dont worry about it,but if not-Get to a tuner and get it set up or your engine might go pop
Old Aug 7, 2005 | 06:15 PM
rs-nut-john
it was around 10psi before and held 8psi, but it was overfueling and sutting the tail pipe up now its a light grey colour without the smell of fuel....but its the noise of the turbo that was worrying cos its well loud....
Old Aug 7, 2005 | 07:34 PM
AJC's Avatar
AJC
my turbo used to make that sound running 16psi, it was the turbo, it was fooked,
in balanced shaft
Old Aug 7, 2005 | 08:53 PM
GrimmeRS2K's Avatar
GrimmeRS2K
u running 18 psi on a standard turbo?
Old Aug 8, 2005 | 09:49 AM
rs-nut-john
i was m8 i turned preload down 2 10psi this morning seems 2 of calmed it a bit...but yep i am running a std turbo with a new -31, but its gotta be ready for going bang cos ive had the car 7yrs and they guy before me had it 4yrs and its never been changed, but the engine is itself is new, std 1600cvh and done 2k....
it was good fun on the way home tho grimme (lucky i think 2)
Cheers ajc, im going to john noble tuners soon to get it all sorted cos it shouldnt make that noise surely.....
Old Aug 8, 2005 | 09:52 AM
GrimmeRS2K's Avatar
GrimmeRS2K
14psi max on a standard turbo, if not it wont last very long!!
Old Aug 8, 2005 | 03:38 PM
JesseT's Avatar
JesseT
Mine has lasted years with ~23psi. Not ideal though I admit.
Old Aug 8, 2005 | 04:50 PM
rs-nut-john
cheers grimme i have sorted the pre-load but the noise isnt getting any worse but it is still very noisey and my arse twiches everytime i hit peak boost as i now wait for the big bang...
JK12
33
Apr 26, 2021 12:09 PM
slammedorion
15
Nov 1, 2015 07:17 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
Churtz
15
Aug 13, 2015 06:40 PM
