Cossie to type 9
Old Jun 26, 2004 | 07:36 PM
Jackass's Avatar
Jackass
Default Cossie to type 9
Anyone here fitted a type 9 strait cut box to a cossie engine if so what starter did you use
Old Jun 26, 2004 | 08:02 PM
markk's Avatar
markk
yes i have !! and still have it !!
and i use a short bodied RS2000 mk 2 or late sierra pinto !!
Old Jun 26, 2004 | 08:34 PM
XR4Timan's Avatar
XR4Timan
I always had a gut feeling the T9 would work
Old Jun 26, 2004 | 08:46 PM
markk's Avatar
markk
u need a diff flywheel tho m8 !!
Old Jun 26, 2004 | 10:50 PM
Jackass's Avatar
Jackass
What flywheel would i need i have a pinto flywheel that i think would work if fitted but would it fit the cossie crank
Old Jun 28, 2004 | 12:46 PM
Jackass's Avatar
Jackass
up^^^^^
Old Jun 28, 2004 | 02:57 PM
Doh's Avatar
Doh
don't think a standard pinto flywheel will work as its 6 bolt and the cossie one is 9 bolt plus its larger
burtons do a 9 bolt pinto sized flywheel, obviously you'd need a new clutch too..
Old Jun 28, 2004 | 04:22 PM
MickB's Avatar
MickB
Ye,thats what i use on my nat assp cossie with t9 gearbox,a burton 9 bolt pinto size flywheel.
Mick.
Old Jun 29, 2004 | 09:07 PM
Jackass's Avatar
Jackass
Thanks for the replys guys just spent £460 of my mates money at burtons
Flywheel, ringgear, paddle clutch and cover just hope it works
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
