Think im losing oil pressure
Old Aug 7, 2005 | 11:37 AM
GrimmeRS2K's Avatar
GrimmeRS2K
Default Think im losing oil pressure
Hi, since i changed my oil to 15w 40w, was on 5w 50w mobil 1, my oil pressure has dropped quite abit, i changed to a thicker oil coz when my turbo blew up a few weeks ago, universal turbos recommend that i used a thicker oil to protect the turbo a bit more, so i changed it when i put the new turbo back on,
looking at my oil pressure gauge, when the engine is hot, im not even making 2.8 bar at 2k revs, only just at 3k, the oil pump is geniune ford one only covered 4k miles along with the bottom end, it was making about 3 bar at 2k revs before the turbo blew and i changed the oil.
ive got some castrol rs 0W 40W what i picked up from halfords cheap a couple of weeks ago, not sure about putting that in.
If im using thicker oil i take it, its harder to get the oil about the engine?
also i think im due for a tappet change as a couple are noisey, could this be a problem?
cheers
Old Aug 7, 2005 | 05:57 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
What kind of pressure you getting at full throttle and boost?
Old Aug 7, 2005 | 08:46 PM
GrimmeRS2K's Avatar
GrimmeRS2K
doesnt go up much around 3.2 bar, from cold start up before the oil change i was getting around 60 psi but now about 40 psi, somethings not right
Old Aug 7, 2005 | 09:06 PM
Tony Turbo's Avatar
Tony Turbo
Hmmmmmmm, don't sound all that really mate.
I just checked, and I get 4.8bar @ idle from cold, 2bar when hot (90+) and 4.8bar at full throttle, and that is on piss thin mineral oil.
I'm no oil expert, but I wouldn't have thought that a slight change in oil would have effected it like that.
Old Aug 7, 2005 | 09:14 PM
GrimmeRS2K's Avatar
GrimmeRS2K
im gonna get a new cam aswell, coz my kent is getting noisey aswell and want a cam to produce more power than the one ive got, could a worn cam lose me a bit of pressure aswell?
thanks for your help tony
Old Aug 8, 2005 | 08:45 PM
Tony Turbo's Avatar
Tony Turbo
I have heard of, an expirenced severly bad wear on Kent cams, like, knackered within 100's of miles, I would recommend a Piper cam if you were too change.
Not sure if it would contribute to low oil pressure though, sorry. See what Mr C thinks, he isn't doing much tomorrow, only working on my invoice, and the less time he spends on that beast the better
Sorry I can't help anymore mate
SMILER258
Sep 28, 2015 09:04 AM
dombanks
Sep 21, 2015 08:38 PM
