Computer probs agian :(
Old Aug 6, 2005 | 09:32 AM
Rhys's Avatar
Rhys
Default Computer probs agian :(
Right my main computer has been starting up slow reently but this morning it kept frezzing on the black screen after the windows XP loads bit. Then on 6 time it got through to the log in screen but it toke about 5mins for it to load onto the proper screen Once computer is all loaded it works fine!
Anyone know why this happens and what i can do to sort it?
Old Aug 6, 2005 | 10:47 AM
Nath's Avatar
Nath
Take plug out of socket and switch it to the off position
Old Aug 6, 2005 | 10:50 AM
Stu.H's Avatar
Stu.H
sounds like you need a reinstall to be honest.
sooooo many things it could be unfortunately
Old Aug 6, 2005 | 11:49 AM
Rhys's Avatar
Rhys
Doh dont say that
Hmmm hopfully it will alst for another 2 weeks, then the computer can have a long period of rest by then hopfully it will sort its self out
Old Aug 6, 2005 | 12:14 PM
Jim Galbally's Avatar
Jim Galbally
i agree... never worth fixing stuff like that. just reinstall
Old Aug 6, 2005 | 12:36 PM
Adrian's Avatar
Adrian
Had that happen on my laptop HD. Booted it using ERD and chkdsk'd...
more bad sectors than good
Old Aug 6, 2005 | 01:50 PM
Rhys's Avatar
Rhys
U lost me after this point
I dont want to Format really as i got Gigs' of music and films
Old Aug 6, 2005 | 07:17 PM
terrytennick's Avatar
terrytennick
You could try a full defrag and clearing all the shite out of boot (using msconfig) and possibly cleanng up your registry if youre confdent.
Old Aug 6, 2005 | 10:00 PM
SS1's Avatar
SS1
try this
http://www.startupmechanic.com/
if the link dont work you can find it free on
http://www.download.com/
ive got a boosted copy of Registry Mechanic..with user name AS A LAST RESORT before you format ...can send via msn if ya need it
think it still works but havent used it since my new upgrades
regards
Old Aug 6, 2005 | 10:19 PM
Stu.H's Avatar
Stu.H
rhys
when it DOES work and u get into windows, do a backup of everything u need to keep
THEN reinstall
Old Aug 7, 2005 | 12:31 AM
Al Bags's Avatar
Al Bags
Black screen after animated window is usually device driver load problems .. Usually Graphics drivers or chance there is a memory problem (you would have been getting BSOD's) If you changed graphics drivers recently, you should try a restore point back when you know it was ok.
A defrag? Nonsense ... Wont do a bloody thing to help on startup .. The system finds the correct file in System32 folder, then away it goes.
A safe mode boot and chkdisk may also be helpful.
Ignore the MSconfig thing .. Thats not for XP. You use services.msc for that.
Download Hijack This and check for Spyware drivers loading up on start, they can also give an unresponsive boot
If you want hijack this from me, drop me a PM .. but you can find on line.
You dont need to be too drastic just yet : ) You need to show the hijack this log file to someone who knows about computers .. dont delete entries willy-nilly, or you will be reloading the OS
You could benefit from a decent registry cleaner, most do! You can fix a lot more than you would think when you go about it correctly.
One more thing .. If you have succesfully booted, you should clean out everything (incl folders) in Windows/Temp, C/Docs & Settings/Local Files/Temp This is all rubbish that has accumulated. Anything like Temp Internet file folders will be recreated by Windows if needed on reboot. Also clean out the cache .. C Panel/Internet Options/Temp Files/all content.
Good luck!
Old Aug 7, 2005 | 01:51 AM
SS1's Avatar
SS1
words above speak sense when you wake up
a defrag ..
Old Aug 7, 2005 | 10:11 AM
Al Bags's Avatar
Al Bags
Old Aug 7, 2005 | 10:20 AM
Al Bags's Avatar
Al Bags
Hiya ..
If you're really stuck, stick another HD on, use any Win98-on startup disk with FDisk to prep with NTFS, then format with Windows. Drag across all the stuff you want to keep. You can also use the files and settings wizard to save your settings.
Then you could wipe and format the original with the same disk, and load Windows with XP disk. In setup, you will just see disk 1 and 2, and a drive letter.
gcfcos
59
Oct 6, 2015 05:04 PM
AJC
Oct 1, 2015 06:47 PM
Kam B
Sep 24, 2015 10:40 AM
gcfcos
88
Sep 15, 2015 03:48 PM
