Jumpy Rev Counter... Again !! Attn: Electrical Guru's...
Hi All
Posted a couple of years back about a jumpy rev counter in my Saph 4x4 Cossie... before I could try the suggestions it cured itself?
However now it is back with a vengence, and obviously I cant remember what the cure was? Seem to remember it was to earth something like ignition amp, but we have done that with no success (in fact if its possible its worse)?
Any suggestioons very welcome as its doing it all the time now, even at very low revs/speeds?
Thanks in advance
Thanks in advance
i hat that problem on saturday revcounter was jumping around
and also it came of the clock
then my feking spedocable snapped
so been driveing around with no spedo
and gest wat the revcounter
seems to be working again
reaving cleanly feking weird or wat
then my feking spedocable snappedso been driveing around with no spedo
and gest wat the revcounterseems to be working again
Thanks for the replies guys
I am sure someone said it was down to a faulty connection or earth last time, I just cant remember exactly what it was
Back up for the lunch time people...
Originally Posted by RANJ
phase sensor
Can only be possibly this if the car has misfiring issues too.
Kevin B,
Try this....
Next to the coil on the loom is a rev counter filter block.
This is black and about an inch long (bolted on bodywork if escos)
This will have TWO identical cour GREEN wires on in.
Disconnect these wires and temporarily join the wires together.
(only do this if the ignition is OFF otherwise you will get a shock)
See if this sorts things out.
This filter is to prevent radio interference.
One green wire is connected to the coil negative and the other goes to the rev counter.
Thank you all (again)
In the last few days the bouncyness has been getting worse, ie, its now doing it all the time, including on the over-run? It has also developed a slight mis-fire which is barely noticible (its only noticible at low revs/speed), would this point to the phase sensor? If so what/where is it and what do you have to do to it to sort the problem?
Will have a look at the black block near coil (its a Saph not escy) and see what that does.
Thanks for the replies, if someone (Simon?) could answer the above i would be very appreciative
Thanks.
Thanks.
. Harvey has one for this purpose though
