Trader Parts for Sale. Only Registered PassionFord Traders can sell parts in here. Buy with confidence.
-31 Actuators
Old Nov 18, 2003 | 11:27 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Default -31 Actuators
£70 delivered
Old Nov 27, 2003 | 04:42 PM
RANJ's Avatar
RANJ
good price mike
Old Nov 30, 2003 | 05:10 AM
XR4Timan's Avatar
XR4Timan
Delivered to America?? U take Paypal?
Old Dec 1, 2003 | 07:33 AM
Mike Rainbird
Caraholic
No and no .
Old Dec 1, 2003 | 11:04 AM
XR4Timan's Avatar
XR4Timan
D'oh and D'oh!
Old Dec 2, 2003 | 02:24 PM
BigDave's Avatar
BigDave
Mike, just getting into this Cossy tuning malarky so are the -31 better then -34?? Yeah I know I am thick, but an old skool boy has to start some place!!
i am looking at running a 2wd motor on Greens and so want to upgrade the actuator. So this is where you could come in???
CheeRS
Dave...
Old Dec 3, 2003 | 08:05 AM
Mike Rainbird
Caraholic
Hi Dave, there is a post on the General Board detailing the full merits of both. Do a search under "James Raby" and you'll see the title.
I would use a -31 for your particular application.
Old Dec 3, 2003 | 08:09 AM
Stu @ M Developments's Avatar
PassionFords Creator
There you go Dave..
http://passionford.webheberg.com/for...ic.php?t=24096
Good luck, some people seem to have found it confusing....
Maybe im loosing my touch Mike?
Old Dec 3, 2003 | 08:33 AM
SapphyMike's Avatar
SapphyMike
thats cos it was a bit Stu I am sure that i saw a contradiction in there about a -31!
Old Dec 3, 2003 | 08:44 AM
Mike Rainbird
Caraholic
Seemed perfect to me. Depends on whether you want a natural tail off at high rpm or whether you need to hold the wastegate closed with the extra spring tension on the -34.
Old Dec 3, 2003 | 08:51 AM
My saviour..!!
Old Dec 3, 2003 | 09:04 AM
SapphyMike's Avatar
SapphyMike
Stu.
you said that a -31 is useless after 15psi and that its an 8psi actuator and that you have to match the bleed for the psi - you then went on to say that if you want to run 20psi you need to run 10 bleed and 10 on the actuator, but that didnt look possible???? sorry if i mis-read it and am being thick
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
