EXHAUST CENTRE SECTION KEEPS CATCHING!!!
Old Aug 4, 2005 | 01:07 PM
JONATHAN PARKER's Avatar
JONATHAN PARKER
Default EXHAUST CENTRE SECTION KEEPS CATCHING!!!
KEEP CATCHING MY EXHAUST ON SPEED BUMPS AND HOLLOWS IN THE ROAD. ANYWAY TO TUCK IT UP A BIT MORE OR AM I STUCK WITH IT BEING LIKE IT IS. SEEMS TO BE THE CASE ON ANY OTHER COSSIE I HAVE LOOKED AT BUT I WAS WONDERING IF ANYONE KNOWS A CURE!! ITS NOT THAT MY SAFF IS REALLY LOW- FAR FROM IT! JUST THAT IM REALLY WORRIED IM GOING TO LEAVE MY EXHAUST STUCK ON A SPEED BUMP ONE OF THESE DAYS!!
Old Aug 4, 2005 | 04:44 PM
jon@work's Avatar
jon@work
the only cure is fit a magnex or raise the car - common problem with other makes of exhaust
PS caps lock is located on LHS of keyboard - press it
Old Aug 4, 2005 | 04:54 PM
JONATHAN PARKER
haha: its being at work. have to use caps for everything!! looks gash i know!!
year think its a combination of ride hight and diameter of the piping!! well whats left of it! ta for the help.
Old Aug 4, 2005 | 08:22 PM
JamesH's Avatar
JamesH
Weld a straight 3" pipe in there instead and do away with it
Old Sep 5, 2005 | 11:43 AM
Twellsie's Avatar
Twellsie
not sure if a magnex will solve your problem, i am running one and it still catches and if yo u catch it hard it pulls the hole system back so that the down pipe makes contact with the prop shaft
Old Sep 5, 2005 | 01:16 PM
Stealth Bomber's Avatar
Stealth Bomber
My standard exhaust used to catch on EVERYTHING, I mean like a Rizla on the road would do it.
Then I put on a full Mongoose exhaust, and lowered the car, and it catches a lot less than standard exhaust and standard ride height - go figure
Cosnada
Jan 7, 2016 05:30 PM
A.t.p
Sep 29, 2015 05:04 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
