very mad with myself
Doh, if theres no way to sort it, i'd drain coolant, tae thermo housing off, get the nozzle of a hoover in the opening behind the thermo housing to suck out any "swarf"
and drill it out carefully, if you use the right size drill bit you should get away with running the right size tap through it to get the thread out. (thats assuming the temp sender unit can be viewed through the opening the thermo housing leaves? if not im sure the fragments of metal it leaves wont do any harm? pisser
P.s. Also assuming a drill can be fitted in that small space
maybe a short "devil" cheepo electric drill?
I actually sheared my reverse light switch flush with the casing when I was refitting the engine and box on mine. I wasn't very happy either, until I noticed it would screw out with my fingers.
Originally Posted by rs shawn
Originally Posted by series1ajc
yep, but i cant think the hell who
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
