2wd cossie going lean above 1bar
Old Aug 3, 2005 | 07:42 PM
Jay,'s Avatar
Jay,
Sponsor
Default 2wd cossie going lean above 1bar
hi im here again lol right on stage 1 the plugs went white ove a bar of boost just done a stage 3 conversion and its still going lean at a bar checked fuel pressure at idle is ok changed fuel pump and new fuel filter still the same thing can anyone help cos im about to set fire to the thing
cheers jay
Old Aug 3, 2005 | 09:03 PM
Jampot's Avatar
Jampot
I had a fueling problem when i had mine done to stage one , the guy took my injectors out and put them on his injector cleaner and all was well, might not be much help but that was my proplem hope yours is as easy
Old Aug 3, 2005 | 09:05 PM
Jay,'s Avatar
Jay,
Sponsor
nope they have already bin cleaned but thanks its defo a prob on both stages so idont think it is injectors
jay
Old Aug 3, 2005 | 09:15 PM
rossco22's Avatar
rossco22
All i can say mate is stop driveing the car hard till you get the problem resolved, else you may end up melting a plug an recking your engine as i did!
Old Aug 3, 2005 | 09:42 PM
sailorbob's Avatar
sailorbob
What injectors are you using?
Old Aug 3, 2005 | 10:15 PM
rsjohn's Avatar
rsjohn
What chip you using as i expect its in the map thats making it lean
john
Old Aug 3, 2005 | 11:14 PM
Jay,'s Avatar
Jay,
Sponsor
the injectors are 803s and the car was behaving the same on a stage 1 tune chaps
jay
Old Aug 4, 2005 | 01:13 AM
sailorbob's Avatar
sailorbob
803's should overfuel on a stage 1 chip, I wonder if something is causing the ecu to go into a LOS mode and it's using fixed injector pulses. Sounds like someone who knows Cossie ecu's backwards needs to pipe up.
Old Aug 4, 2005 | 06:49 AM
Jay,'s Avatar
Jay,
Sponsor
no now its on a stage 3 pts chip mate
jay
Old Aug 4, 2005 | 05:53 PM
davidreader5's Avatar
davidreader5
HI,
Have you the correct plugs, heat range fitted, and haS the co% been set
for and checked on idle and cruise fuelling, you say you have checked fuel pressure, should be approx 3.bar at idle, and 3.5, bar vacuum, pipe off.,
have you done a fuel delivery check to check pump and lines and filter,
check with chip company for co% figures for set up. plus you say injectors
have been tested for flow, we had new and one was faulty untill flushed through
for, about 5min's. and your boost is well below max limit of 3bar setup with 803's,
so cant be that. are you using super unleaded.
DAVE R.
Old Aug 4, 2005 | 08:55 PM
Jay,'s Avatar
Jay,
Sponsor
yes im useing super dave checked the lines today and boosted fuel pressure everthin is cool the plugs are ngk 8es
cheers jay
Old Aug 4, 2005 | 09:35 PM
davidreader5
JAY,
Well doesent make sence if the boost , fuel pressure, all above is correct, does it
idle ok,(if not may have vacuum leak) as plug colour indicates not suitable by
colour range to engine, lean, were these plugs in both setups ,stage 1 and 3,
if the same plugs, and running lean on both chips 1/3. all above good, try
another set of plug's,,,, when you look at the plug is the insulator of the plug
down in the plug or on the outside of the plug, if cold plug or turbo plug the insulator part should be down in the plug, and a hot or N/A engine plug is longer
on view more, is the engine temp normal,, may be worth checking the coolant temp sensor, the one which tells the ecu the engine temp for mixture related info,
blue sensor , at the rear right side of head inlet manifold side. also have you now
since stage 3, have 3,bar map sensor, as its getting the wrong signals somewhere.
DAVE R
Old Aug 4, 2005 | 09:40 PM
Jay,'s Avatar
Jay,
Sponsor
hi dave ive used the same plugs and the top of the plugs go grey/white but inside they go light brown and all the sensors seem to be fine but i have lost the list that u sent me a while ago with all the setings on
jay
Old Aug 4, 2005 | 09:47 PM
davidreader5
jay,
what info do you need and i will send it by email,
is the car 2wd, or 4/4.
DAVE R.
Old Aug 4, 2005 | 09:49 PM
Jay,'s Avatar
Jay,
Sponsor
2wd dave the ohms reading off all the sensors please
jay
Old Aug 4, 2005 | 10:08 PM
davidreader5
jay,
just sent by email in pdf file complete info including what you need,
upload is about 6min's, let me know if you get it, as will redo,
DAVE R
Old Aug 5, 2005 | 10:57 AM
Jay,'s Avatar
Jay,
Sponsor
ok dave ive measured cranksensor at ecu plug like the infor said it says 600-1k the sensor read is 666ohms
phase sensor the book says700-1.2k the sensor read is 806 ohms
coolant sensor is to the book
map sensor with ignition on 1.52v book says 2.2v
on idle was 0.6v book says 0.6v
throttle to the book to
so im thinkin to what u said about the plugs mabey there to hot so whats the happy medium for a 2wd
jay
Old Aug 5, 2005 | 02:56 PM
davidreader5
JAY,
Each to there own, but i had ngk's plug's for a bike, 3,plugs one was faulty
after running till engine got warm, so since dont use them, most people
swear by them as best, i buy ford plug's AGPR 12PP8'S UP TO 1.6,BAR,
and AGPR902P COOLER THAN PP8'S, FOR 2,BARMAX,, sensor wise the main sensors to check, map, throttle switch,and coolant temp sensors are all checked,, your map sensor is 3,bar so will have different reading to book data std 2,bar.?? As all seem's to checkout everything above, try plug's Fuel delivery after regulator 2.5litre's a min, or devide by 2 for 30seconds.
DAVE R.
Old Aug 5, 2005 | 03:09 PM
Jay,'s Avatar
Jay,
Sponsor
dave ill check the fuel delivery i have checked the runing of the reg on boost itll go past 4 bar so it does seem ok and ill order a new set of plugs ive also booked it into power engineering in 2 weeks cos i think it needs proper setup mabey the fault will show its head i would just like to say thanks for all ur time an effort in tryin to help me
cheers jay
Old Aug 5, 2005 | 03:21 PM
davidreader5
JAY,
NO Problem, here's a pic of my car just finishing restoration and
added, cossie management. all my own work.
DAVE R.
Old Aug 5, 2005 | 03:38 PM
Jay,'s Avatar
Jay,
Sponsor
thats a credit to ya dave looks proper mint what power is it runin is it a cvh or zvh
jay
Old Aug 5, 2005 | 03:51 PM
davidreader5
JAY,
Waiting on a ecu to run, but keeping it 200bhp, approx untill can
uprate or change box, and clutch, it's a CVH, may put in a full zetec later.
done a lot of work done over the past year, from floor pan's to sill's, inner bays,
engine rebuilt inc L/Balanced, cosworth brakes, etc. just moved into a new unit,
not much left to do.
DAVE R.
Old Aug 5, 2005 | 03:53 PM
Jay,'s Avatar
Jay,
Sponsor
oh do you do cars for a living then
jay
Old Aug 5, 2005 | 04:02 PM
davidreader5
Mainly as a hobby, been doing cars for approx 19 years
but i may be with a mate who is a fabricator by trade, go into business
doing car under bonnet parts ACCESSORIES, and one off fabrications, and car work FORD, RS, i want to get more into engine after market management ECU'S. and conversion's. i've chipped cars but that is pretty
basic just adding chip, and injectors , checked fuel pressure, set co%
etc. all the main work has been done in the chip. especially
if you start from fresh files,
DAVE R.
Old Aug 5, 2005 | 10:46 PM
Ian M's Avatar
Ian M
your problem may be voltage at the fuel pump is low. quite common now due to old wire.
Old Aug 8, 2005 | 11:50 PM
Jay,'s Avatar
Jay,
Sponsor
checked this ian but thanks for input
jay
Oranoco
41
Feb 11, 2016 01:28 PM
mark r
Sep 29, 2015 07:27 PM
arfurski
Sep 26, 2015 10:39 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
