Weak Actuator ?
Old Aug 3, 2005 | 07:08 PM
DaveSeries2's Avatar
DaveSeries2
Default Weak Actuator ?
As above, how do I tell if the actuator on my series 2 is weak ? Is there any way of testing it ?
If it needs replacing should I replace it with a standard one or can I fit a -31 ?
Any help or advice would be appreciated.
Thanks in advance,
Dave.
Old Aug 7, 2005 | 10:36 PM
JjCoDeX75's Avatar
JjCoDeX75
Hello m8
The actuator can be tested, but needs to be done with special equipment, ie a pressure gauge and the use of some compressed air. The pipe is taken off the top of the actuator, and air is blown. The pressure shown on the gauge when the spring activates (ie when the bar moves) is the pressuire that the actuator is set to.
Probably best to take actuator off the turbo, and take it to a local friendly gargae (prefferably one with exp with turbo cars).
If you are having trouble with boost, and the actuator is working, on the Cossie, the amal valve (and people messing about with them) can cause most of the trouble. However, I have no idea whether the same setup is used on a RS T
Hope the above helps
JJ
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
