Sierra 4x4 housing on an RST
Old Aug 3, 2005 | 09:28 AM
davidnormanuk's Avatar
davidnormanuk
Default Sierra 4x4 housing on an RST
Hi all,
When I first fitted my Turbo with a 4x4 housing the car seemed to pull really good. But now the turbo seems to be really laggy and hardly seems to be pulling at all. I have had to put the standard ECU due to my other one being faulty so am limited to 10psi. With the bigger housing on and the standard ECU should it still be pulling away as at the minute it feels really flat or is this because it need more boost to use the full potential of the Turbo?
I am thinking about replacing the atuator to see if this is the cause but if anyone has got any ideas it would be a great help.
Dave
Old Aug 3, 2005 | 09:38 AM
mart.rs's Avatar
mart.rs
so you just switched back to the original ecu and havent had it set up ?if so your fue and air will be a over the place,so im not suprised its all over the place!
Old Aug 3, 2005 | 09:52 AM
davidnormanuk
Thing is even with the Chipped ECU the car still didn't seem to pull as good with the new Turbo on as when I first put it on. The car's been set up with the standard ECU on. I'm thinking it could be the actuator. Its one of them bling ones which I got off Ebay which was new. I've been told by various people that these ones arn't that good and don't last 2 minutes. Should the car pull ok up to 10 PSi with the bigger Turbo on as it's flat as a fart at the minute?
Old Aug 3, 2005 | 10:25 AM
GrimmeRS2K's Avatar
GrimmeRS2K
get a garret -31 mate, there the ones i would only use
Old Aug 3, 2005 | 10:34 AM
davidnormanuk
I'm gonna see if I can borrow one off a mate to see what the difference is. Its might not be the actuator but its worth a try.
Dave
robbo9006
11
Sep 1, 2015 02:10 PM
andyrs1600i
Aug 30, 2015 07:21 PM
Roosie
11
Aug 22, 2015 10:13 PM
dlwarrior
Aug 5, 2015 10:19 AM
Old ford
Jul 31, 2015 06:50 AM
