Will a S2 diff go in a S1 box?
Old Aug 1, 2005 | 07:09 PM
James's Avatar
James
Default Will a S2 diff go in a S1 box?
As title, i seem to remember the bolt pattern is different but juts wanted to check?
Old Aug 1, 2005 | 07:33 PM
S1 JOHN's Avatar
S1 JOHN
they dont fit mate there is different amount of teeth between the two my mate put one in it screamed like crazy
Old Aug 1, 2005 | 09:43 PM
James's Avatar
James
yeah but is it possible to swap the crownwheels?
Old Aug 2, 2005 | 06:56 AM
JesseT's Avatar
JesseT
The layshaft and crown wheel should be a pair as ford has used so many different ratios and toothsizes. The S1 crownwheel to diff attachement is by 6 bolt where as the S2 has 8 bolts. This means that we have a problem. You can take the crown wheel and drill four new holes and tap them to M10x1, but I warn you, that material is pretty hard. Better find a different diff or a matching layshaft/crownwheel combination.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
