BIG BHP engine....5k
Engine.........12miles only
7.9-1 comp...WRC 4 layer gasket....all cometic engine set...grp a bolts...6 paddle clutch (2000 miles)...genuine cossie pistons with valve cut outs....big ported head....new exhaust valves....cams suited to engine spec!......swedish plenum with enlarged 2wd throttle body...4 x 1000cc injectors...L8 ecu....Norris motorsport chip!.....samco full boost/water hose set...2wd manifold using PJ link pipe with GT35 1.06 exh houising with suited external wastegate...bailey turbo damper.....needs proper air filter as only rated to 500bhp...BRAND NEW std crank and balanced std rods......3 bar map sensor
5k or nearest offer...this is seriously CHEAP.....would break for the same if stripped easy
