Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Gracey Engineering - at it again :cry:
Old Aug 1, 2005 | 12:29 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Default Gracey Engineering - at it again :cry:
Today people i will invite you into how to fit a breather kit
1 - remove camcover and damaged gasket to reveal the dry sump conversion that you never knew you had
2 - Use a syrynge and piece of vaacume pipe to remove all the oil from the sparkplug trays, and then use suitable mopping up items to get the last of it, Clean sparkplugs in white spirits or petrol
3 - While the camcover is off, this is a very good time to fit your breather kit. Drill thru the camcover at the rear where the cast circle is and then tap using a 3/4 BSP first tap to start the thread, Make sure your taps are spotlessly clean and apply grease to collect any swarf and also to act as a cutting lubericant.
4 - Once you have run thru with a first tap, clean out any swarf using whatever you want, and then run a plug tap down the hole.
5 - Now clean the plug tap untill there is NO swarf on it at all, and then run it dry down the hole from the top of the camcover - this will remove any small deposits of swarf in the threads - as pictured on the tap
6 - Screw in your 3/4 BSP tail and use a suitable sealer on the threads to stop oil passing them - i used an extremely thin layer of Sikaflex - this will garantee any oil NOT getting past
IT IS IMPERITIVE TO CLEAN ALL OF THE CAMCOVER INSIDE TO REMOVE ANY TRACES OF SWARF!!!!!!!!!!!!!!!!!!!!!!!!!
7 - Refit camcover using a NEW gasket and then pipe everything up - as you can see, mine isn't quite finished, as i am waiting on silicone hose
There ya go - the Gracey school of engineering does it again - i think i need to have my own section on here for all the DIY stuff i do and detail
Old Aug 1, 2005 | 12:38 PM
AlexF's Avatar
AlexF
looks smart....
this is the one you built ya slef isnt it?
Alex
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Good show Gracey
Old Aug 1, 2005 | 12:39 PM
Graceland's Avatar
Graceland
Team HOTHOT!
it is the one i made myself yeah
just waiting on a camcover gasket now - i ordered the flocking thing 16 days ago
Old Aug 1, 2005 | 12:40 PM
JamesH's Avatar
JamesH
Top work mate
Old Aug 1, 2005 | 12:44 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Bet that syringe has been used a few times on other jobs eh mate!!!
Old Aug 1, 2005 | 12:45 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Lee_R21Turbo,
Old Aug 1, 2005 | 02:02 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
PMSL @ Lee
Top work Paul
Old Aug 1, 2005 | 02:17 PM
rsnissan's Avatar
rsnissan
Looking good
was there acutally a rocker gasket there the 1st time round
Old Aug 1, 2005 | 02:18 PM
Graceland's Avatar
Graceland
Team HOTHOT!
there was yeah - it split when i had the camcover off the other day, but i never noticed
Old Aug 1, 2005 | 02:28 PM
Gra's Avatar
Gra
looks good,engine bay look wicked in general, whats that purple thing by the powerstering tank
Old Aug 1, 2005 | 02:29 PM
Graceland's Avatar
Graceland
Team HOTHOT!
thats the oil catch tank Gra
Old Aug 1, 2005 | 02:31 PM
Sticky.'s Avatar
Sticky.
Gra's Avatar
Gra
looks pukka my good man
Old Aug 1, 2005 | 03:10 PM
KSA-Cossie's Avatar
KSA-Cossie
Nice one gracie m8.
Old Aug 1, 2005 | 05:46 PM
pee vee's Avatar
pee vee
nice one gracey!
does it work alright
Old Aug 1, 2005 | 05:54 PM
James's Avatar
James
Cool, whats the difference between a standard tap and a pipe tap?
Old Aug 1, 2005 | 05:59 PM
Graceland's Avatar
Graceland
Team HOTHOT!
a pipe tap - water comes out of it, and you cannot thread holes with - a tap tap you can
and a tap dancer, well
Old Aug 1, 2005 | 07:05 PM
James's Avatar
James
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
muz
Aug 16, 2015 12:57 PM
