mk4 escort headlights
Old Jul 30, 2005 | 12:29 PM
haz87's Avatar
haz87
Default mk4 escort headlights
How the hell do you remove them
Old Jul 30, 2005 | 12:33 PM
RSandy's Avatar
RSandy
shud b a simple undo of the bolt/bolts that u can c holdin the light via a bracket at the inside of each light, kinda on the slam panel if u get me.
then there a little black screw type fitting on the inside of the wing, twist that, and light can lift off that.
then its just a matter of pulling it to pop it out of the ball joint holding it in at the bak of the light, and it SHUD just pull off.
of course dnt forget to remove the wiring from the bak aswel, as that cud b embarrassing!!!! lol
Old Jul 30, 2005 | 12:50 PM
haz87's Avatar
haz87
cheers mate, ill give that a shot later. The screw thing seems extremely tight but ill give it another try
Old Jul 30, 2005 | 01:09 PM
RSandy's Avatar
RSandy
screw thing is always extremely tight 4 sum reason, so i get hold of a big pair of grips and persuade it to turn!!! lol
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
markk
Sep 9, 2015 08:11 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Adam Graham
Sep 6, 2015 06:04 AM
Bighandsuk
Sep 2, 2015 05:23 PM
