BEST SPARK PLUGS FOR STG 1 4X4 SAFF???????
Old Jul 29, 2005 | 11:06 PM
Twellsie's Avatar
Twellsie
Default BEST SPARK PLUGS FOR STG 1 4X4 SAFF???????
I have a 93 K 4x4 saff that has a missfire just bellow 4K, jsut chasing all the obvious routes, coil, dizzy, leads plugs. Done the first 3 but just woundered whats the best plugs for a stage 1 saff 4x4?
cheers
12s
Old Jul 30, 2005 | 07:56 AM
daz1968's Avatar
daz1968
I have a 3dr, just used standard plugs gapped at 0.7mm, but when I get my stage 1+ Karl has told me to take a set of 071's with me so will be using those, and they are cheap to less than Ł12 a set from ford.
Old Aug 1, 2005 | 09:35 AM
Kam B's Avatar
Kam B
lots of people recomend different ones, i was recommende the pp8s for my stage1 2wd also they good 4 standard too
karl norris recomended them
Old Aug 1, 2005 | 05:59 PM
Twellsie's Avatar
Twellsie
hmm, this is now getting a lil bit confusing with karl recomending 071's and PP8's for the same application
Old Aug 6, 2005 | 03:51 PM
daz1968's Avatar
daz1968
I think at stage 1 there are a lot to choose from , pp8's are platinum so would last longer than my 071's but are also about 3 times the cost, so choice is yours.
Old Aug 6, 2005 | 03:53 PM
KSA-Cossie's Avatar
KSA-Cossie
Fitted 071's to my stage 3 4x4 today and took a beasting down the test track ok earlier.
Old Aug 9, 2005 | 07:10 PM
rabmc's Avatar
rabmc
Whats the part number for th 071`s ? or is that it ? going to get a set of these next week are the okk in your car kev ? what boost u running with them
Old Aug 9, 2005 | 07:12 PM
snow*'s Avatar
snow*
I use Motorcraft APGR-12PP8's on my Stage 2/3 Sapphire.
I was recommended them by Simon at Woodford Garage Motorsport
Old Aug 9, 2005 | 07:44 PM
KSA-Cossie's Avatar
KSA-Cossie
The finis code is 1120834 rab,22 psi running perfect.
DixieTheKid
11
Jun 6, 2020 11:20 AM
mpilk
Sep 27, 2015 09:21 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
pabloXR
Sep 21, 2015 12:42 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
